Pippo9Gol
Good morning.
as from title, I wanted to understand if there is the possibility to print from dwg to pdf several windows on a dwg without having to convert every single window once at a time... .
by the way, I have a dwg with different frames (an electrical scheme), so:
when I convert to pdf, I impose the sheet size a4, dwg to pdf, and choose the method "window" by selecting a window at a time.
then I join all pdfs with a program specifically.
I wanted to know if I could avoid converting each single pane.
when I convert to pdf, I impose the sheet size a4, dwg to pdf, and choose the method "window" by selecting a window at a time.then I join all pdfs with a program specifically.
