automation ipart connection break
  • Thread starter Thread starter 3olo
3olo
Hello.
project with inventor 2013.
I would have a problem: I should make hundreds of almost equal parts for a library, and this is not a problem, I create an ipart, I add all the lines I want with the various sizes by spreadsheet and ok. The problem is that then I should open all one by one to disconnect them from the mother ipart, so it would be a madornal job.
It doesn't seem to me that as an option there is to disconnect the file automatically when you generate it, so I would need something that allows me to select all the files, open them, unplug them, save them and close them, all in one shot only automatically, leaving the computer to grind even a few hours, but at least I would avoid grinding myself for a few hours!! :-)
You know how I could do that?
Thank you in advance
you could try with ilogic or from a set to create a cycle that opens the files by deactivating the iproperty
Thank you very much for the answer, but could you explain yourself better? I am not really practical with ilogic unfortunately . why rename them files? If I understand well you would say to put all the files in a set and turn it is ilogic rule created, right?
I'm not the best with ilogic, but some results have managed to get it.
as soon as I have a little time I do some tests and if I get results I will tell you right away.
I'm sorry, but I can't do that.
Great, I'd be immensely grateful, man, opening 3000 pieces and disconnecting them takes 10 hours by hand. If you try, I'll be delighted. kinda
I couldn't find a solution through ilogic seems to prevent ownership management, I deduced that if an ipart is created it is precisely to speed up creation and modification, so it doesn't make sense to interrupt the coll for the files.
but why do you need to stop the link?
you can publish the part as the part
I have to do some kind of online library with all the generated components, and I wanted to avoid downloading the components should click on "until" to the request message of the connection with the ipart father. but I think I'll leave him like this and peace
- - - updated - - - -I also saw that there was no ilogic command unfortunately! Well, thank you for trying!
