automotive - funnel cad,methods and analysis changes
  • Thread starter Thread starter wjmat
wjmat
Hello everyone
to those of the profession I wanted to ask how best to manage these phases of the design.
this phases are manageable mostly with the gsd so I posted here, if there was a better section moved as well...
Specifically:method
  • 1 initial method for handmade quotes, with powerpoints or with other?
  • 2 method 3d formed by a product with by-products for each operation or all in the same part?
  • 3 final 2d method made in power point or catdrawing?
cad imbutitura
  • 4 built with particular sequence? example stoppers - tangent outputs - punzone wall - ray cap - premilamiera - ray matrix - edges puzzle
  • 5 construction made to maintain the upgrade in case of arrival new element? es use of extreme controls, flat offsets etc.
  • 6 fin development with manual constructions or with power copy?
  • 7 use of cat addon for quick creation out figure? es. dynavista, icem, pam diemaker
  • 8 variable beams made with variable radius or use of only fitting between surfaces?
  • 9 spoils made as? by hand,isormorphism,coating surfaces or other software?
  • 10 unloading negative rays? by hand, with reduction of rays of core and cavity design or other?
  • 11 increase mating surfaces on swab matrix made with simple offset on the faces and without fitting or other?
  • 12 matrice spoiling for deformation mazza press by hand, with padding or other?
management and updating new details
  • 13 analysis of modification of a hand-made element with sections and views or other? es compares dmu space analysis products
