automotive suspension spring(machine constructions)
  • Thread starter Thread starter A14000060
A14000060
calculate the required length of a rear suspension of the type to longitudinal arms knowing that: the rear wheel radius is 260 mm, the accepted life is 300000 km travelled at an average speed of 30 km/h and that the variations are induced by wavelength road bottom wadings of 5 m.:smile:
life accepted is 300000 km it runs at an average speed of 30 km/h and that the variations are induced by wavelength wavelength wadulations of 5 m.:smile:
I sold the good beyond useful life, maybe it lasted so long because most of the time passed it on the highway so maybe the condition of the 5 meters was not so tight. :smile:
Back to topic:
students are normally asked to propose a solution scheme that is then commented and discussed, so it would be good for you to set the problem, and then receive suggestions for improvements and corrections.
Back to topic:
It wouldn't even be bad to pass through the presentation area first.http://www.cad3d.it/forum1/showthread.php?p=279079#post279079and do what normal education suggests.
then... copy and paste the text of the problem... without even a commentary."Do you do my homework? ", He could write it. . .
-- it's like entering someone's house and asking for food without saying goodbye.
As you have guessed, your approach to this forum has not been the best, you are not the first and you will not even be the last one to "find" at the beginning.
Since it often happens that a new user gets attached to this forum a little.... uncommonly we say, I made a miniguide for novices; read it and... correct the tio.
Bye.
