(autosez 2) soil sections and profiles - automatic extraction
creates two text styles with name as-quote e as-legenda using the fonts you want, if the program does not create them.
if the expedient does not work attach a dwg that contains the model to "find" and the screenshot of the autosez dialog box before giving the ok
I followed these steps (see related screenshot attachments):
  1. I created a 2d polyline representing a profile to be faked;
  2. I created the two text styles you told me to create and the cad makes me create them;
  3. I made appload of autosez;
  4. ho lanciato la lisp;
  5. create me at the finish!
but if I go out from autocad and return with a new design I return to have the problem before.
It seems to me that the problem is that the 2 text styles are not automatically created.
in fact launching a new instance of autocad and making immediately the upload of the lisp, after there are not created text styles.
What relationship can there be with these indications I gave you with the autosez.dat file we were talking about yesterday?
I don't know why one or both styles are created.
you create the two styles in the pattern design, so you will always have them available.
no one, in that file settings are saved for the next launch of the command.
deleting it, in case of problems, autosez departs with the default data, as at first use.
other times this suggestion had solved the problem that had arisen.
Okay, I followed your advice and modified the acadious design.dwt.
Now go.
Thank you!
