autosk seek import walls and roofs
  • Thread starter Thread starter giorgiosindaco
giorgiosindaco
hi everyone apologise if I open this post but I did not find the solution in the search.
My problem is as follows: if I unload walls or roofs from the site autodesk seek I can not add them in families walls or roofs.
How do I do that? if I design a roof with my revit architecture 2014 I can choose only between three types: base roof 27 and 31 cm and tilted glaze. How do I open others and add new ones? same speech applies to the walls.
thanks to all
I think you're messing up.
walls and roofs are system families that exist only within a project file or possibly a template. you can not download families of walls or roofs but only open projects in which lori types are contained and transfer them from one file to another; as well as of course personalizzartele you duplicating the existing and changing the parameters.
methods range from the very trivial ctrl+c ctrl+v to the tool transfer project standard.
I do not understand that in the autodeskseek that is a "container" of loaded families there are also walls and roofs, but, I repeat, they also have to be content in a project file from which you can then transfer them.
But there's no doubt that you're creating to download families. Home on walls or roofs?
Yes, I do.
I'll explain to you I want to make a roof full of beams and tiles. seeing the various tutorials on the net is not difficult only that I have a problem I do not know how to load the various materials. As for the beams first the load individually and then use beam system instead with the tiles I do not know how to do. in the tutorials the tiles are among the materials but I do not find them. How can I do that?
I downloaded from autodesk seek these tiles:http://seek.autodesk.com/product/la...boral-roofing/1piece-claylite-chaparral-blendHow can I put them in my roof?
Yes, I do.
Forget those are American covers....if you really want an Italian roof follow these instructionshttp://www.cad3d.it/forum1/showthread.php?3381-coppi-in-3d&highlight=render54of the great render54 you can also download a video where it explains step by step how to do.
p.
if you really want to use revit a tip: read a good manual and follow a course.
Good luck :rolleyes:
Thank you very much. . .
I am studying on the official guide of revit 2012 of hoepli
