ggg
Good morning to all,
I am trying to collect data on the average hourly rate by type of mechanical processing, specifically milling and turning of metals, and type of machine. by hourly rate I mean the total cost (handling, machine depreciation, etc...) which is then used to calculate the final price according to how long it takes to produce the order.
For example, the hourly rate for a complex workmanship such as the milling of a part with a five-axis working center will differ from a simple turning or two-axis milling process, so I would expect that an hour processing at the lathe costs less than a five-axis processing. I realize that these values can vary very much depending on the geographical region, workshop size etc... but I was looking for an average indicative range (for example, simple turning 40-50 euro/hour).
Thank you so much!
Thank you so much!
