axes disappear in the drw and i can no longer view them
  • Thread starter Thread starter MORENO100
MORENO100
Hello everyone,
I would like to know if these two problems have already happened to someone and if he managed to solve them.
in a drw if by mistake I select a shown axis and I do button desto > deletes instead of eliminates, the axis disappears but how do I then review it?
second problem that perhaps leads back to the first.
I happen to reopen some old drw rather complicated and wanting to make some changes, I can no longer view and then show gi axes of some features. The only way I have to review the axes is to erase the whole view and recreate it as a new one.
I would point out that I have already checked that all layers of both the prt and the drw and the views are shown.
I thank everyone who wants to give me an answer
Hello everyone,
hi for the first case, in theory if you delete the axis you remove it own with the exhibition and delete (torch icon) selecting the axis type precisely, it shows you all the axes of the part or together loaded into table.
idem for the second do everything with the exhibition and delete.
I have already tried with the exhibition and cancels but does not detect these axes.
Other information:
- if in the drw click on the "visualization axis" button all axes appear with relative id, except these that give me problems.
If I open the part and do the same operation, the axis looks like everyone else.
Does anyone have any idea how to solve the situation?
then it should be tied to the layers.
Do you know that in drawing there are also layers of views? Did you check this?
First of all, I thank you for your concern.
the question of the layers of the drw or the part or the views and all the rest I have already considered and tested but nothing changes, even to simplify and study better the problem I tried to erase them all from the model, but nothing has changed.
I wonder: is it possible that no one else has ever had such a problem?
I remember in the past that something similar had happened to me on some files prior to 2001, and the only way to solve it was precisely erasing as you rightly said the view, or recreating ex novo the axis.
the symptom was precisely that, despite activating the axes in part environment, those axes were actually not shown yet exist, but it only appeared in cases where the axis in question was generated by a feature, example a cylinder, or all those axes that were created by portions of arches, there is in fact an option in the config.pro that governs the self creation, instead all those axes created as reference the problem did not exist.
I think it's the same problem, unfortunately.
hi moreno excuse if I ask you trivial questions, did you do new installations or changed something in configuration files?
