axiemi display association
  • Thread starter Thread starter Ilario
Ilario
Hi, everybody, I haven't been here for a while, but I wanted to ask for something.
inventor 2010:
when creating axioms from scratch, the display of subaxieme components is associated with the subaxieme itself; i.e. if I open a subaxieme of a main set and hide some component, in the main axieme is hidden there as well.
sometimes, however, while working in the main axieme of having to hide individual subaxial components without being there to open the subaxieme and punctually appears the window with the choice of "remove the absoluteness of the view" where otherwise does not make the operation to hide the main component together.
Now I would like to understand if somehow, after "accepted" of losing the visuality and doing other operations, this thing can be reversible and return with the association of visualization of the components according to how they are put in the subaxieme.
I hope I explained.
I solved:
from the main axieme expands the subaxieme node, dx key on the node representations of the subaxieme, you choose representation and from the window you select in the first tendon the name of the representation (created in the subaxieme and that it must be different from main as blocked) that you want to use; now just above, the voice "public" (in case it was not already selected) is split and "associative" appears.
