axiemi in the library
  • Thread starter Thread starter Fabbbio
Fabbbio
hi, I like many of you, created my ipart library in my content center, my question is as follows: is it possible to insert in that library of the assemblies? For example, I should insert hinges, or other simple axes composed of 2/3 parts.
ps: use inventor 2010
thanks for the prompt response. .
My little assemblies are already iassembly, but cmq can't fit them into the library as the button for publication is missing. . .
but if you don't work in group and maybe you don't even use the vault, you can't make a library as a simple directory and go fishing the assemblies from there?
Yes, I think it's the only solution, even if it's a limitation for me that I can't put in the c.c.!
Thanks for the advice!
mha, I've been working like this, and it seems even more comfortable than cc.
create an axiemi library project or how the hell you want to call it and fill in the above directory.
then, add this directory as a library to other projects so it also becomes unchangeable. ....
I work equal
I also have a problem similar to that discussed in this post:
I wanted to insert in a bookcase the axieme of a plastic hinge composed of two equal "half-hungry" to reuse it in the future.
I followed the board of tarkus and everything went well, but I would have a question: if I needed to change the hinge inserted by the library how can I do?
I should change an angular bond between the two "half-try" so as to verify the apex of a door.
Any suggestions?
Hello everyone and thank you.
Any suggestions?
save the set out of the library, change it as you want and return it to the library.
do not change the angular bond, suppress it.
when inserting the zipper set into your general set, make it flexible so you can get it to assume any position.
Bye.
...... ...... an angular bond between the two "half-try" so as to verify the apex of a door.
Any suggestions?
If your bookcases are under a "free" project, all you have to do is go to that project and change what you want.
even if you don't want to get out of the project you're working on, you can open another inventor session, go to the library project and edit.
Of course, in the other session you don't have open files containing the component you want to edit.
with regard to the specific hinge:
-not create it with angular constraints,but let it free to rotate normally; When you put it in a set, the "flexible" flag appears for that axieme.
and if you want to put angular constraints, put them to the components that are attached to the zipper.. .
I followed your advice and the problem was precisely in the angle bond that I had inserted into the zipper axieme, suppressing it and making the flexible zipper work properly.
thanks for the tips!:finger:
