axis line break at quotas
  • Thread starter Thread starter Login
Login
Good morning.
opening an old drawing in archive, I came across a view that presents the axis line interrupted at odds. I tried to see if I could find some setting, but without outcome. I attach an image to clarify.
if someone were so courteous to explain how to do... use I create 3.0
hi search in the help
creating a break in a model axis line
... select insert (insert) > interruz (break). . .
I use an old version but there is the way
and to eliminate interruptions
change/remove/all interruptions.
found, thank you.
I hope it's something that's been set up with later versions of creo.
I find very little smart the fact that the same function has not been made available even with the right mouse button.
