backup
  • Thread starter Thread starter blubossa
blubossa
I have a rather complex subaxieme and I would like to make a copy of back-up that you carry all the drw.
I tried both the axieme and the drw of the axieme but the drw just can't carry them back.. .
How can I solve this?
bb
with backup does not carry behind the drawings.
the only way is the save copy but you have to rename all files (parts and assemblies).
Bye.
bb
the only salvation is plm. :-)
if you save copy and the option of the config rename_drawing_with_object is set on both resolutions.
implementing the pdm only for this seems to me an exaggeration. pdm helps in so many things and it is definitely a useful and important step that a company has to do but for a semblice backup of files you can solve as I told you.
Bye.
Bye.
I tried to do as you say, but the drw don't back-up...
If you can tell me where I'm wrong?
bb
Hello blubotage
I managed to do so thanks to weblink, analyzing the structure and bringing behind the drw without rename anything or changing the config (only a registry key for the too many cycles of internet explorer in the case of gigantic assemblies)
We also added a purge.
The problem is that we have to plan to achieve this.
If you're upset, we can feel in private mail.
Bye.
mine was obviously a joke related to a recent discussion with blubossa, obviously you are not aware of it so avoid making certain comments out of place.
the rename_drawing_with_object is certainly not a solution, it is just a bypass....
