Barriers
MARCOC
and possible in addition to display the center of gravity..poter decide with odds where one wants it and to make compute to inventor
the mass and location of where to add it
impossible? ? ? ?
impossible? ? ? ?
impossible not for a limit of inventor but for the infinite solutions of the problem itself (distribution of mass)
but that you know there are no programs that can do it
the problem is not being able or not to do so.
the coordinates of the baricentro of your volume v body (x,y,z) are defined by integrating on the volume xdv, ydv and zdv.
Now you can quote a point that you choose to be the center of gravity (x,y,z), but for that center there are infinitesimal integration and therefore mass distribution to the same.
inventor and other programs do well things that make sense but above all possible.
within the dynamic simulation of inventor and using design parameters you can optimize the weight and balance of the body, but narrowing in any case the "infinite" field of possible solutions.
and with all the difficulties, not trivial, of the simulation area.
