batch file loading problem
  • Thread starter Thread starter salvatore87
salvatore87
hi to all I have created a tree pattern to optimize, but when I load the file in txt format, me from some error messages such as (keipoint1 belongs to line1 and cannot be moved) all related to the construction of the model.there is to say that all the model and static analysis were made in interactive mode, and everything went the same way, but when I follow the optimization process are not done.
You could help me fix any errors.
Thank you! !
You got a lot of work to do on this file.
I give you a number of tips:
1- never call variables with the same command name ansys (for example I see "r=2": change name)
2-if your input file serves for optimization you have to insert at first a set of commands that completely eliminate the mesh and existing geometry. in fact the first simulation round can work, but then in the second lap you go to recreate the geometric entities that already exist... must be erased together with the value of all variables.
3-clean your file because it's a slaughterhouse! open it with the note block and then 5-10 row blocks make a paste copy on the ansys input window, checking step by step what it is doing and if the instructions are correct
4-rtfm (abbreviation that stands for "read the fucken manual") - "advanced analysis techniques guide - design optimization". and also read the apdl programming part.
- Good luck.
Thanks for the help but I solved all the problems I had, and I completed the argument.
