beam44 orientation
  • Thread starter Thread starter antoniosism
antoniosism
hi I have a problem regarding the orientation of the sections:
I have a 3d frame consisting of 4 sections to l which I can't orient. How do I solve the problem?? ? ?
I shaped everything with kpoints and lines
hi pasquale I tried in all ways even with theta but the only effect is to rotate the local axes but the section I always see it unturned
You got it?
model with knots and elements.
define the knots (e.g. 1,x,y,z) and then connect the various knots to form the structure:
(e.g. type,1 real,1 mat,1... en,1,2..etc)
the only thing you have to be careful is to write the moments of inertia of the axes correctly (this you need to "route" the section.
