You have to do a set.hi guys, I should set the size of this bearing at 0070-22
But when I go to insert the bearing in the part I have no way to select the size, how can I do?
thank you all in advance!
Hello, Marco.You have to do a set.
now you are inserting/importing a "body" in one part; Imported bodies are not editable unless, if you kept the link to the original part, do it directly from the father side.
Did you get the bearing from the toolbox?
However, that is a classic case of environment together.
Mar
