lorenz0
Hello, everyone, I'd need a hand. I should make a mounting of a rotating shaft on radial ball bearings with calettamento on conical shaft ends. Can someone help me figure out how to do this? Thank you in advance.
First of all what you can't do?I should make a mounting of a rotating shaft on radial ball bearings with calettamento on conical shaft ends
I'm an engineering student. I studied both the scholastics and the bearings, but in this case in particular I do not know how to move. Until now, I have had easier fittings, such as an ad or x generic assembly. now the doubts I have are about how to block the bearing near the conical tree end and therefore where there is also the hub (eg a pulley).First of all what you can't do?
What are you studying behind you?
All you have is a description?
Okay.beyond the seeger you can lock with nail and shoulder, spacers, washer and screw... all go well in the right configuration
when you have free time I would like to deepen with you the theme of this principle of motion, so I can write notes and share them....rotation happens according to the principle of the buttered cat.
you don't understand if:Hello, everyone, I'd need a hand. I should make a mounting of a rotating shaft on radial ball bearings with calettamento on conical shaft ends. Can someone help me figure out how to do this? Thank you in advance.
the site Skf has many explanations...google knows when everything...a research before would not be bad.Hello, everyone, I'd need a hand. I should make a mounting of a rotating shaft on radial ball bearings with calettamento on conical shaft ends. Can someone help me figure out how to do this? Thank you in advance.
disappoint me.when you have free time I would like to deepen with you the theme of this principle of motion, so I can write notes and share them.
I have some doubts about a classic mounting with two radial ball bearings.Yes, because in the absence of space the two bearings would be free to flow axially towards the inside.In this case the screw 7 will go to push the sleeve 2 until you get to the line. In this case, do you need spacer 8?
Yes, it should be, because by doing it deeper, the particular 2 would go to bat against the inner ring of the bearing and tightening the screw 7 would block axially the tree as the thrust would act against the package consisting of: internal ralla bearing right, spacer, internal ralla bearing left to discharge against the tree line; bearings would not be subject to axial preload.in the presence of the spacer 8 I am told that the seat that makes the joke could be deeper than the tree inserted.
if there was no spacer 8 and the bar was still deeper, tightening the screw the right bearing would move axially to the left, moving away from the external seeger and causing the axial game of the sleeve. There would still be no preload on the bearings.If there was no spacer 8 and the batutta was still deeper, it would go screw pushing the bearing ring, in this case it would be incorrect because it is radial bearings and can not suffer precarious of this type, correct?
in this video explains very well the principle of cat buttereddisappoint me.
is the first principle of physics.
since a cat if dropped will always land on the legs and that a stewed slice if dropped will always end on the part with jam, just tie a biscotted slice on the back of a cat and let it fall.
and here is the perpetual motion.
