Beginner aid for model
  • Thread starter Thread starter Alcoltest
Alcoltest
hello to all, I am a beginner, you know how to make this model all united and full? use 3d build and as soon as they select the various parts and unisk locks everything....
I have never worked with objs because the cad I usually use does not support them, nor do I know 3d build, the only suggestion that I can give you is what I do when amount steps that instead of being generated as integral solids are generated as parts faces:
- select the part in question and use the command "show spaces".
- the various holes in the surface are highlighted through the edges that surround it.
- I close the holes using the command insert faces and once closed all the holes in automatic turns the face part in solid part and I can work there.
