Andrea23390
Good evening, guys, I'm a think3d novel since I started using it today. I did a lesson in the unit with an English version and I have an entire pantry with English commands and I can't find the respective in Italian and unfortunately on the command is not marked the icon.
what I have to do is after creating a line that starts from the work plane origin (work plane) and having created a rectangle create a reference to convert the central line to a geometric reference.
-use make reference to convert the centerline into reference geometry.
here I miss this step to start designing.
at this point I should do the same with the rectangle and then use the constraints to connect the pieces.
Can you help me? Thank you so much!! ! !
Andrea
Andrea
