best sets with a hp designjet 510 plotter for autocad printing
  • Thread starter Thread starter joeblack
joeblack
Good evening, everyone.
I would like to optimize once and for all my plotter hp designjet 510 a0 in order to be able to print with autocad 2012 of the technical tables from architect, therefore mostly lines b/n (85%), little color, if not for retinatures, and photo of the size 10x15 max, always inserted in the tables.
What resolution do I have to set?
what quality I have to set, considering that I noticed that higher quality and more time it takes to dry the paper.
do I have to set the overwriting lines for you?
the type of color srgb or what?
I mean... the settings of the various tabs on driver preferences.
I hope that whoever has my own plotter can help me (naturally even those who own other models. . . )
thanks to all
optimizes for design/text as they are mainly architectural boards.
quality? does not make sense as question, depends on the result you want to get, higher quality, more printing time and more cartridge consumption. but if they are boards to deliver better use that.
the rest leaves everything as it is.
In any case, if you do some evidence, you'll be more aware of it.
hi joeblack, I take advantage of the fact that you also own a plotter hp designjet 510 a0 to bring a question.
Unlike you with regard to the printing of the boards containing exclusively cad drawings I find myself very well, colors and lines are printed perfectly.
the problem arises when I insert images (predominantly it is rendering images or photomodeling), the print is opaque and little sharp (as if there was a greyish filter on the whole image, just to make the idea), the colors do not match. I tried to print a portion of the table with a hp a3 printer (1280) and the quality is clearly better.
I set from the menu of the plotter "optimizations for images" and "improved colors", the card set is the one actually used... but nothing, bad press (well, not really bad but almost).
Can you explain to me what I may have done wrong in the settings?
