best software for plants style assonometric section
  • Thread starter Thread starter campione
campione
Hello everyone
I would like to draw plants of buildings seen as if they were prospect vertical sections, I show you an example image (in attachment)
which software is convenient to use x do something like that?
thanks in advance :)
revit o, se non hai budget sufficient, revit lt
Hello, thank you for the answer
can you have exactly this "crash" effect with revit?
You say they used revit for this image? or is it a general advice you give, to get something like that?
What effect do you mean? to me it seems a simple b&w perspective.
to give you a vague idea, questo stand was designed with revit. It's a stupid example but it's so much to make you understand what types of representation you can generate with revit or revit lt.
p.s. the figures in the second page are not rendering
p.p.s. with the new version of revit/revit lt you can also produce theseSpaccatoR14.webp
I refer to the style of the lines or details, to the silhouettes of the people and to the way the furnishings are represented, which makes it seem almost a handmade design
while the one you post is similar but appears more like a technical design, more "rigid" as style
I don't know if I'll explain.
but where do you see it I am drawing "almost" handmade?? If I had posted something like that I would have given you reasonciti-sketchup.webpbut the one you indicated has nothing vaguely similar to the sketch
possibly with building design suite, using revit and sketchbook, in a few minutes you can generate thissketchbook.webp
possibly with building design suite, using revit and sketchbook, in a few minutes you can generate thisView attachment 33170
the sketch style to which I refer is the fact that it seems almost a hand drawing style lecorbusier
I thought I didn't mean that kind of sketch (otherwise I used sketchups, with its unclean lines and styles in some ways).
and the type of detail is not technical but simpler, even for the furniture, and the variety is multiple
what I would like to understand is if there is a program that allows you to do this quickly and with the same type of detail
If you want to model every single thing, or import blocks with a different graphics from this, I know very well that you can do with any program
I was trying to figure out how to do something really similar, not a cut 3d or a prospect plant that is...
for this I hoped to find someone able to give me indications recognizing the style and type of detail of that image, depending also on the used furniture that certainly was not modeled piece x piece by who made the design
from the details of the design, and the call to "families" seems to me a specific sw for the interior decor.
in this forum, I'll talk about furniture sw....
