betting instance of family table and the asm at reopening gives me error.
  • Thread starter Thread starter malamente
malamente
I'm sure it's a newbie question, but I'm freaking out and I haven't found any arguments about it.
I created a (generic) part with family table, and when I go to assemble it in an asm x use the variant of the case, say a1.
if I close create, when I reopen program and asm x, the asm goes wrong because it does not find the file with name a1 of the variant, as there is only the file with name a of the generic .
Where am I wrong?
I thank all in advance for the patience of having read and even more who will please respond.
more than an assembly error seems to me so much an error due to the location of the file a (generic and istance) that are not found in the same working dir of x or are not mapped as search path... But I might be wrong, you should see a little better in detail.
hi apologise for intromission, the problem happens to me too:
after creating the family table of some vines, and having created a special path, if I insert into a set any screw gives me error to reopen, surely is the problem of the working directory, what solution is there? I don't think you have to save the screws in the right folder to make it work. Thank you to anyone who will answer.
Do a test, first open the offending ft variant and when you have it in session try to load the axieme where it is mounted
I think it's just about setting the search paths correctly if you work with the files in different directories.
