biella-manovella animation
  • Thread starter Thread starter usamx7
usamx7
Good evening to all, I just finished a 3d set of a biella crank mechanism:
would someone explain to me how to perform the animation and what constraints to apply, to have the movement of the mechanism?
I regrate in advance. Hi!
make a pack & go of the together and attach it.
Bye.
here (in the file you will find also the crank, with a problem in the tilted part, in paratica I can not remove part of the material, creating like two wings. If you know how to remove them, let me know, thank you! )
Okay, why? You want to see it? :smile:
to be able to tell you which bond to animate.
constraints are a matter of how one prefers to work.
It is difficult to say do so or so without seeing how you have bound.
Do you want to do the animation in the environment together or study?
Bye.
There's no file.
Okay, I'm going home now, and then after dinner, I love him.
I've seen some things that aren't good.
the approach to the sketch must be rigorous, the sketches must be completely bound.
the color of the sketch lines changes (in my case I use the black bottom) from cyan to magenta, only at that moment you have the bound sketch.
to make the tree, for example, your initial sketch (dia. 60 ) that generates extrusion 1 is completely free.
having this sketch positioned well compared to the original plans is fundamental for the success of the movements.
I don't use msn but I have skype, there's the connection under my avatar.
If you see me connected, you're allowed to call.
I have inv. 2009 & 2010, so whatever changes you had to do on your files you could no longer read it.
Bye.
Okay, but if I add you to msn, can we still talk, even using you skype?
In any case, even if you change those files, it doesn't do anything, I think then I make changes in my own, followed in the procedures by you :finger: hi!
I'm trying to get this biella moving, too.
I've done a biella piston before.
I will make an allrial when I have time.:finger:
Thank you so much pietro46, I would really like a tutorial, it would be very useful! Thank you! :finger::smile:redface:
I turned your files into step so as to bring them neutral in inventor 11.
I set them up with the plans positioned in consistent points and I reconsidered the set.
If you look at the constraints I applied you should be able to understand what I did.
animating the corner bond between the crank and the plan of origin you will see cinematism move.
I decided to turn everything into step, losing your sketches, just to show you the constraints necessary to move everything.
As I have already written to you at 7:21, your sketches need more care, that biella totally without quotas made me shiver.
the parametric makes sense if you put the shares on the sketches that generate the work.
If you want, take your details back in your hand, set them up and put them back.
Look at the birth. " Native modified tree " and compare it to your original, note how much smaller the working tree is.
I have a son of your age and, with inventor, made the same mistakes.
Unfortunately by self-taught it is very easy to acquire wrong methods.
Bye.
Okay, I'll take a look at them, thank you! Anyway, I created a skype account, and I added. as soon as you can accept my invitation, so that I may contact you, and clarify any doubts. Thanks again. Bye!
I did so: and very simple but the biella alone can not perform any function.
mancha the shaft the piston, cylinder head, transmission. And then we can take a walk.
:finger:
I hope you can see what I did. and what works?
Hi stefano, we're not as good as you.
I'm an amateur with inventor.
we study autocad mechanichal.
in September we begin with the great inventor.
last eastate I got a book for inventor 2009
that explains it very well. but also here if you deal with people like you. I'm from poko and I'm trying to make some allrials on mechanichal.
Okay, bye. I have to draw
:finger:
I can't open it, because I have inventor 2008. Would you send it to me with that version?
Well I did it this morning at school with inventor 2009,
and now open it with 2010 and all right.
I don't know how to save it as an autocad (Save for 2008) you can see it with 2008.
but sorry if you're a student you can have it for free because you don't try 2010?
I get everything free from autodesk through school.
then with 72 euros I bought a license for 5 years of which ce inventor mechanichal and autocad, I think it is possible also in Italy.
If you're interested, I'll explain how to do it.
