ManuelT1993
Good morning.
I'm a new member of the forum, although I've wanted to sign up for a long time.
I am currently a mechanical engineering student at the fifth year.
I am learning thanks to a book the basics of creo parametric 6.0.0, now I am beginning to create small assemblies with top-down methodology.
My problem is that I cannot assign the constraints to the parts created by this method, so created in the assembly environment.
using the bottom-up technique I manually insert each part and therefore I individually inserted each bond.
I tried to take inspiration from this discussion https://www.cad3d.it/forum1/threads/vincolare-part-creata-nellassembly.51880/ But I couldn't.
I tried to find other methods, but nothing.
I explain to you with a very basic example:
part 1 I created it with this menu
I then selected the reference system and created the part with the usual methods:
then click on create and to create the second part use this menu:
I opened part 2 in a separate window and defined the 3 floors default, so belonging to part 2.
I created the plunger, drawing the sketch on the upper circular face:
I can't define the course constraint at part 2, certainly wrong with some reference or plans.. .
certainly this is due to my inexperience with creo,any help will be well appreciated.
if there are no details, write as well.
Good day
I opened part 2 in a separate window and defined the 3 floors default, so belonging to part 2.I created the plunger, drawing the sketch on the upper circular face:
certainly this is due to my inexperience with creo,any help will be well appreciated.if there are no details, write as well.
Good day
