black and white print problem in autocad 2013
  • Thread starter Thread starter flynight
flynight
Hello everyone, I have a problem with black and white print. I imported a color jpg file in autocad and at the time of printing(from model) all settings to make the print in black and white: monochrome printing style, customize printer property and I inserted black and white. the problem is that still color printing. Is there any other setting I miss?
the image does not take into account the ctb. if it is in color, stay in color.
the only setting on which you can act are the general settings of the printer, from windows
Alternatively you can change the image (by autocad) and make it into shades of gray
come
how can I make the image in shades of gray?
if you are in model space verify to have set the 2d wireframe display style
I did, you mean printer property, right?
That's right. as well as the sect would print a pdf in gray scale.
if you can't print pdf and then print the latter
all printers are set to print in color or scale of gray.
said this, by printing from autocad, if you can't set the printer, you will print with color image, resulting in having a color pdf
this pdf opens it with acrobat or similar program and the grayscale molds
Thank you so much. I've done it now.
