Spit19
hello to all boys,
after searching on the forum and seeing examples that you have attached I can't realize the sunset I have to make.
in short I tried both as part and with sheet.
I drew the two sections skecth (the first circular the second rectangular) then I activated the parallel blend general selez skech (until here no problem then from here on it always gives me error saying that the skecth is incomplete or is allowed to make only one loop per section and sincerely I try and try again but nothing to do.
I have also seen from the examples the circular section is made by four arches which I used to make a circle before..... but I couldn't... .
some good soul can guide me step by step!!!! ! ! ! ! !
I use wf4
I use wf4
