blend
  • Thread starter Thread starter mtvonno
mtvonno
hi, according to you to switch from a circular section to a polygonal, the right command is the blend?
I used limit blend with old versions I think it's surface blend?
allego creo 2 files
to get a regular surface I divided the sections with 20 equidistant points, relative to each section, in height.
the blend is fine... but is there an even better way or other commands or combinations of multiple commands? ♪
