block with image
deep70
hello to all
I have to insert notes in a 40n of drawings, in these notes there are also business logos, now I would like to build a block to recall it then to need but I can not save the image of its logo, or better insert it and once saved the block the logos do not remain.
Thank you as always all in advance for any given answers and good day to you.
Hi. I assume that your need is to have a sort of paperwork to be inserted in the drawings, so you should create the block for all other entities and then create a drawing format with the block and with the image. then the format insert it into the tables. I have my boards made like this, because I couldn't even insert an image into a block.
hi drake, I just solved in this way, I redesigned the logos as sketches inside the block recalculating the image precisely... Fortunately they were not very complex.. Of course the colors I didn't put.. I tried with filling but does not take color. .
if it is always the same you can create an image, externally sw, formed by notes and logos and then insert image
I tried.. so doing the image does not remain part of the block.. is how to upload any image on the table though. therefore that not bound to the block.
in fact the images do not remain within the blocks. then the blocks sincerely have many problems, which I also reported here in the forum not finding the solution. the thing that sends me to beast is that it enters modality block and go to change a note, save the modified note and inside change block you see everything correctly. save the block change and the note magically returns to be as it was before the change! change lock and see it modified! I gave up and every time I need to change, I exclude from the block the notes and edit them out of the block and then reinsert them.
we can say that as regards the blocks we can make improvements in sw.. but for all the rest remains the best in absolute... It doesn't rain here.
Yes, I think so. all the software have pros and cons, however, but the choice I made on sw oramai several years ago was the fruit of seeing nefandezzes from the direct competitors.
