blocked table
  • Thread starter Thread starter andrea1974
andrea1974
Hi, in the attached table you see that it was stuck in the template, I would need to unlock it to fix, for example, the amount coming out of the field, I don't find how to do.. .
Does anyone know?
question... did you make the paper?
If not...change the table in the cartiglio I think they are connected by colliea.
try also to select the whole table and make it lock and unlock everything. . .
I would change the font... just try to decrease the text size. . .
cmq without the file to check, there are other options that I don't know how to explain.
we changed it from standard ones and put it on the template but I don't know how to open it to change it
selections the column-> mouse button->formatting
1690977094028.webpor select the whole table from the left corner at the top and then -> mouse button->forming
even better if you do not want to change the size of the columns, make fit text(suitable text)...you adjust it automatically. select only the quantity box.
perfect. but if I want to change the template as I open it?
go to the template folder and drag it to solidworks (if you have pdm check out first) then sheet format and do edit:1691066900011.webpchange the sheet and save it as sheet format.Untitled.webpThere are many tutorials on how to make the template. . .
