drake
Hi guys, in the table I realized that often using blocks that contain simple notes with only text, at the time of the change of the block to change the notes, it seems that everything works but at the rescue of the block x magic recompete the old note! If I return to the change of the block I see the note as modified and if I go back the old one. He doesn't always, but often he does. so every time I am forced to remove the note from the inside of the block, to instruct it and then reinsert it inside. did you also find this characteristic "pittoresca" and in case you know how to remedy it?
