lakiway
hi guys, I have to draw a 3d model of a reel consists of 3 columns, each formed by 5 coils. I have to develop a 3d model and I can't. thanks in advance for every help.
carro volaff, a coil is an electric machine that needs a support, since, once run by electric current exercises a magnetic field not indifferent. to ensure the stability of the field lines the coil must be bound to a mechanical support adequately dimensioned. why I asked the question in the section "for mechanical designers". the model to be realized is in 3d, second reason why I chose this section. thanks to autocad, perhaps you do not know, from a 3d model you can develop a system in which you see the agents forces, system that the software solves and allows to trace the standard mechanical diagrams. I spent 1 minute responding to your answer, useless and without foundation, which simply denotes your "not knowing". next time you save sarcasm. If you are a senior user and provide these answers, perhaps you should change forums. Have a good day!Nice presentation!
cmq apart from the jokes I suggest you present yourself in the appropriate section and post the problem in the "ad hoc" section!
your problem does not know what it is and how to help you.I have to develop a 3d model and I can't
