boiling with asterisk
deep70
Hello everyone,
Can you tell me why I don't get boiled despite the properties being compiled and the distinct is therefore complete and therefore right? in fact only part n°9 appears as from attached image.
I'm pressing that the model didn't do it, I'm developing its tables.
grace to all in advance for any given answers.
Clearly, some reference is not correct. you are using the item position numbering. Did you try the same article to put it in a different place?
I've already tried. I also tried to restore the properties.. but nothing.. It's the first time I've been. then the distinct that is right is even more strange.. Things should be connected. . that is, if the distinct is right, the ball should match. . .
take the view and click with the right and make property. tie to that view the corresponding table. only so you can be sure they're tied together.
solved, thanks to mechanicalmg and boulders, the view was linked to another distinct, now I linked it to the distinct that interests me and the problem is solved, as always thanks guys very useful. Good evening to you.
