bolla 3d note
  • Thread starter Thread starter jury
jury
pro/e - the question is simple:
is it possible to insert a bubble note in the modeling environment? ?
you need to create a bubble symbol (on a drawing)
and that insert later into modeling environment.
hinges
Last night I was going to tell you that you can't do it, but then I kept from doing it because of my poor knowledge of proes. is not more convenient to create a note as from the menu? you just need a handful of seconds
That's what I want to do.
create a bubble note with the simplicity of a note, but does not exist the command?
I thought so, in the drawing menu there is an icon with the show\erase torch from where you can recall axes, notes, quotas already present on the model. You know what I'm talking about, right?
However, there is the possibility to filter the baloons, but what if I do not find the possibility to insert them in 3d mode? ?
I'm sorry, but by reading your last post, I think I didn't understand. do you want the notes in drawing or parting? In the first case it is very easy and there is no need to insert them into the part. In the second case it is not immediate and then you have to follow the instructions they gave you in the previous posts.
I would like to put them in the part in order to be able to bind them to the surfaces and parameterize them according to measure made. and then display them in drawing....
