marulanda
Hello I have a problem that I can't solve I have tried in many ways, I give you help kindly because I don't know what to try anymore.
the problem and banal, I have two audiences one from 3mm and one from 2mm. are attacked by two bolt m5 8.8 nominal preload 6500n.
I have to apply the preload.
I tried to apply the preload with a thick thermal load and inserting contact between the surfaces of the audience (I used the bctable sensa friction obviously).
The plates are meshate tet10, the bolts are cbar and are attached to the rbe2 plates (hard links).
the problem is that the bolt contractes, and crushes the plates, generates a stress of enormous von mises in the same, ciraca 500mpa (admissible 230).
nastran use, patran for simulation.
How is it possible?
Did I do something wrong with modeling?
Thank you!
How is it possible?
Thank you!
