bolt simulation
  • Thread starter Thread starter Joseph71
Joseph71
I have two bolted plates, which to simulate a bolting, I have to insert the coincidence bond. the problem is that having 4 holes, and inserting more constraints of coincidence, they go into interference. So I ask, how do two bolted plates simulate? ... what constraints should I put in? ...
I did some tests, obtaining that in order to simulate a bolting between assembly without constraint, between the joints you must insert a constraint defined by the user, excluding rotation.
