bom - eliminate separate component and mass calculation
  • Thread starter Thread starter leleallariscossa
leleallariscossa
Hi, I have to delete a separate component (it must be visible at the table, drawn), my questions are:
-How can I exclude it from the distinct without creating variant to which to connect the table?
- How can I recalculate the mass without this particular?
-How can I display this component with dotted lines?
Thank you all.
edit: I used reg.ripetiz. - filters - per element to eliminate unwanted components from the bom.
now, how do I exclude them from the calculation of the mass of the axieme?? I can't even set mass = 0 kg!!
edit: I set the weight = mp_mass parameter in the subassieme of which the mass should not be calculated, after which in the father I inserted the weight report = mp_mass ("") - then I clicked on the upper brackets, selected by hand the weight parameter of the subassieme, to compose the final weight report = mp_mass ("") - weight: 11 where 11 is the number assigned to the selected parameter by hand just before.
remains like displaying a child of the assieme at the table completely with the dotted lines. . .
