elpado6872
Hello everyone I would have a problem with the correction of some bookstores.
practically when I run a library that is linked to a part and then save the library, then the one tied to the part does not update, i.e. it remains equal to before even if opening the library you see clearly that the change has been made.
as maybe it is a software problem I tell you that I use solidworks 2010 64 bit sp 0. the solution that I aduced is to delete the library and tie the correct one again but so the quotas of the 2d tied lose the references.
if someone knows how to avoid deleting the library and updating it without just untieing it is well accepted.
thank you all bye.
thank you all bye.
