Hi, I would like to know where I can download libraries to install in the content center of inventor 2010, I currently installed only the iso and does not let me select any other library.
inventor already has all the normalized components libraries, you don't have to go looking for anything else.
if you have personally installed you should have seen that there are various libraries that can be installed beyond the iso.
However, if you open the installation you should get it directly (or almost) new to the library screen, without re-installing the program. .
a tip: in addition to the usual iso,din,ansi etc, if you want to have even one, check also the "other" library box.
I have already tried to reinstall and arrive at the screen but does not make me make any changes or spitting other norms I can only remove the existing iso norm without being able to apply other thanks x the suggestions that you can give me
Hi there
