epasinet
I've been jammed. I'm not doing the right way, tell me if I'm sacking.
As an attached design, I would like to remove from the building the geometry in red and then put in its place another factory body that will be higher than that to cut.
the problem is that if I use the instrument "operations with solid elements" select as objective element the walls and falde, and as operator element the red parallelepiped, when I execute the subtraction, archicad does not erase the red parellelepiped but leaves it on stage and if I gate, the bonfires and previously cut walls are restored losing the cutting action!
Does anyone have advice?
