Kaji
I would need a great courtesy:
instead of a cylinder iso 15552 of the bosh 0822123007 alesaggio 63 race 200 I have to mount one with predisposition of pneumatic brake side stem so as to limit the race.
Unfortunately I am not practical in this field and I have not been given the references to which to ask, I know only that the so-called brake should consist of two semi-boils governed by a pneumatic valve to close centers, that close on the stem blocking it and limiting the race.
In the annex there is the cylinder that was previously planned, I would need the configuration with the added brake or at least a datasheet from which to obtain the intersection between the two pins of the cylinder in order to remake the movements.
thanks for the availability.
