braces
  • Thread starter Thread starter wergax
wergax
will it ever be possible (if it is not already in some way) to combine more restraints/fillments together?
if I'm not mistaken from the 2018 version they introduced the possibility to associate the restraints to a level (and therefore to have the "colored" restraints), but it would be nice to have solid fillings with the restraints above. .
I imagine, for example, the section of a glass where you can have a blue filling with the "glass" dashes above.
Bye!
as a rule is not something that follows the norms. if you do color views and striped restraints.
if the area is already dissected and fill
if the area is not already dissected and you have to do two fillings after the first right-click on the area, other selection, face and do new filling
from what version is it possible to do this? the last time I checked by selecting a sectional detachment it was only possible to change the detachment, not to add things...
as above, if I select one thing with already a restraint I have always opened in the features manager the options for that restraint.. I have never seen/find a chance to add a second.. .
in the image:
solid blue restraint
black escher restraint
simply increases the need to make the boards more understandable even to those who are not "studied" or otherwise faster reading.
and would not be more intuitive a note written "glass"?
no, as you should read the note, see what is applied and understand the limits of that part/section. ..see a blue profile for example, which detaches from the rest as coloring, is definitely more immediate... =)
as it should be done there is written in my profile the version.
I already explained how I did, but you didn't explain what procedure you used
I can't add more than one annotation-draft over a sectional detachment
And how many should you put?
and the solid replenishment covers me all if done as annotation
because they are displayed in order of insertion. put the section dot as solid and annotation, which is inserted after, you will see it
another that education lost her on the street. It doesn't even sound like I've solved it.
Sometimes I feel like a hooker and I miss a pat on my butt give me...
