tele5palla
Hello everyone, I ask your help for a job I have to do for the university.
I have to recreate a tubular frame of motion starting from some photographs. I have aligned quotas and distances from the symmetry plane of the welding points. the prof authorized me to use the photos as if they were perfect projections. so I have to recalculate the photo by autocad and then by means of the depth quotas check the aligned quotas.
in the photo there is also a segnent of known length, which must serve me for the scale. I would now like autocad to point out the 1:1 scale odds also because then I need the spatial coordinates of the points to continue the work.
I hope I've explained and thank you for your help.
