bring more dxf/dwg to the same layer
a system variable is a command acts on how to behave of autocad and not of the individual document.filed is a system variable because it applies to any design and any work session; set the variable and when you reopen it after a month that setting is still valid. some variables are managed by options and configuration file, others should be launched specially. I attached a pdf with system variables.
garden is not a system variable because in a new design is no longer valid.
thank you every now and then would not hurt, I am not the servant of the gleba!!!
Thanks massive, and a little too big topic then... I stop to figure out how to make some small script work
Thanks again
