broad guard disassembly
Emc2
Save we have to mount a wafer dn 500 valve for upstream water of a turbine for the production of electricity. the valve will only be used for maintenance of the same . the installation will be made underground creating a well between the arrival of the tube and the entrance to the central
on one side the pipe is blocked by a concrete plinth armed on the other simply underground but being the very compact soil I would say that the pipe is blocked. for the installation we will cut the tube we will climb the flanges and insert the valve . in order to facilitate in the future the disassembly thought to put to the valley of the valve a tube trunk (l=500) with other 2 additional flanges welded inclined (clearly also those on the tube will be inclined) in order to facilitate once removed the screws the extraction of the trunk and once created the question of the valve via an exhaust.
Roberto.
