bubble of multibody parts
  • Thread starter Thread starter teseo
teseo
I would like to know if it is possible to bubble a multibody part;
I have a team formed by two bodies a single part; in the table I would perform a bubble of the two bodies and then connect it to a separate table materials, but it always shows me the parts not the bodies (then the table is formed by a single entity the part).
I solved by writing in manual in the bubbles; But it doesn't seem like the best solution... .
The answer is yes.
but are you making a side table or a set?
but are you using a distinct material or cutting?
but in the part you created the separate cut?
The answer is yes.
So... .
I’m running a part, I’m using distinct materials and no I did not perform separate cutting, being part(no welds no sheet) doesn’t make me distinct cutting
I have the strange impression that the last question is escaping something
If you don't have a separate cut (which should be used in part drawings) you can't brand anything.
if you insert a distinct material (which should be used in drawings together) you will always have a voice
So you have to:
- create the cut distinction in the part (insertion >) and fill it
- insert the separate cutting table in the drawing
