bug creo parametric m010
  • Thread starter Thread starter Alberto.E
Alberto.E
hello to everyone, in the studio we decided to install the release m010 of creo parametric. at first it seemed ok but I noticed that in the design environment I create crashes and "thinks" a lot when I click in the tab "annotations" or noted for those who have the English language and the same behavior has it when I confirm the creation of quotas, notes etc. In short, all the operations that are done in the tab annotations are very slow and I create to think a lot before I let myself continue.
All this happens to me with drawings that have 5-6 sheets and many views but I can assure that the same design with the build f000 did not give me the same problem.
the potential of the computer is not to be discussed because even that has not changed and it is a very performing machine.
is this anomaly to you? Do you have to wait for the m020 to be able to work quietly?
thanks for the attention.
tree
ok, perfect but I was interested to know even if the problem that matches is common in the build m010. what release do you use?
hi alberto do not know if my test is comparable to your situation.
I did not put on the table with 5/6 sheets.
I opened a drawing with heavy views to handle and with two sheets of this type.
I don't match your problem.
I did the test on a windows 7 64bit pro machine, 8gb ram and nvidia picture fx 2000 m
thanks maxopus for the test you did.
I have as the impression that it is not so much the heaviness of the axieme from which the drw derives but the amount of sheets and annotations (quotes, notes, symbols etc.).
I also mount windows 7 64bit and 8 gbram. I do not have a picture but a geforce but I assure you that with the f000 and the same design the problem was not there. boh, I'll wait to install the m020 to see if something changes.
perhaps it is better if you contact the customer care ptc or your var.
because it is strange this decay of performance from f000 to m010.
I would not want that in the final release they had modified some settings on the drivers of the video cards.
In theory, geforce wouldn't be good for creo, but if the f000 was spinning...
I have also invoked the same problem in the previous version proe/creo! I had to remake some of them in the table because it was hallucinating the waiting time between a command and the next (of the order of minutes!). all on machine windows 7 compatible 6gb ram, etc.
I also had to completely review the configuration files and for the passage to the new version I never lost so much time like this!
the impression is that certain choices have been well evaluated. I hope that ptc will put a piece on it. So far I still regret the wf4 version!
aminati
I confirm that with the m020 version the problem has disappeared in some cases and reduced in others.
Now at least I can work without too long waiting times.
thanks to all
