bug resolution faster (hopefully)
  • Thread starter Thread starter SolidUser
Risoluzione
  • Fatto
    Votes: 5 71.4%
  • Non mi interessa
    Votes: 2 28.6%
  • Total voters
    7
  • Poll closed .
SolidUser
as you well know the er (enhancement request) have scores.
said this I wanted to help us to increase the score of some er.
how to increase the score:
1) go to the er section of the customer portal (attached image)
2) type the number of the interested spr and press 'search' (attached image)
3) add the data and your comments and press on the 'save details and vote for this enhancement' button.
If you have your own er whose solidworks has confirmed, put them here and everyone,(hopefully), will vote it.
553483 be able to create a rolled part from a flat 2d profile
150188 interference detection should have the ability to filter out interference of matching threads, and
not show them in the list of volumes.
509183 ability to select a component in the ga to replace another component
23066 show degrees of freedom for a component (in assembly, motion simulation...)
542057 allow 'edges' from live section to be used in sketches e.g. for convert and offset
468820 add ability to see rulers and use instand 3d when creating section view in part or assembly (similar to live section)
536833 ability to lock down, constrain and/or ignore the remaining rotational degree of freedom on cylindrical components without having to add an extra mate.
267918 add a system option to set the view to be normal to the sketch plane when editing or creating 2d sketches.
543977 option for 'pack and go' to gather the original files from their various locations into a single folder instead of gathering together a copy of them.
541523 ability to support angular running dimensions (like ordinate dimensions) as specified in iso 129-1
542221 allow smart components to create features in multiple base parts.
544001 provide ability to choose what bodies to keep for a combine add operation. similar to union trim in catia
541565 various ui & usability enhancements for i3d move face command
402112 it is not possible to enter negative values for dimensions in 3d sketches
181450 fit ( approximate or convert) a spline into lines and arcs
546241 allow an open profile to be used for a revolve-cut feature.
545365 ability to playback the feature tree to see how the part was built
2739 highlight dimensions in the model graphics windwo that are used in an equation while editing the equation.
22863 'measure' should appear in rmb menu over edge, faces, etc.
548278 allow creation of section views in parts and assemblies using 3d and 2d sections
At the moment I can't vote, the solidworks site seems planted. Tomorrow night, if everything works, I vote.
As soon as I can place those of the welded, even if it wasn't er, maybe they can vote.
Meanwhile I place the numbers of the two sprs of the welded that are torturing me: 561958 and 561959.
The first one is available to all and I voted for it, the other I made a request that I be notified in the event of a resolution.
I deleted some messages, I don't want the authors, just to keep the thread "clean" as required.
Hello everyone, great initiative!! !
I didn't think you could do this (I always underestimated the appeals of re_solidworks as I thought it should be reported to your var
- what has often been found useless-).
I wanted to report yours first and then propose mine spr (software performance report) con codice: 516396 of 2009, never resolved, now, it seems, even deleted:
But I have problems following your instructions and I'll show you what I see in the annex...
in practice to me does not appear a single box where to enter the number, but many other boxes, inserting only my number or even one of yours and sending, the result is always empty.. .
I'm sure I'll have to fill out other fields, but what?
Perhaps I should indicate my serial number?
Help me?
At the moment I can't vote, the solidworks site seems planted. . .
ps: with chrome it seemed planted also to me (it went everything except that section), with ie instead I managed to the first blow... If you want to try. . .
Help me?
I'll explain something.
the spr can be assigned to two situations:
1) problem reported by the customer, for example yours.
This implies that technicians, after a first verification that it is not due to some incompetence of the user, take charge of the problem and check whether it is your problem or related to the software.
if the problem is a kiss of the program, an er subform of spr is not generated, clearly tied to the spr of your sr.
but is put in the tail to all the basins.
You won't find this spr in search of er...in fact yours don't find it.
2) if instead a customer reports, which fails to quote in orderly polar, a spr is generated as before, then seeing that it is a lack, as sw supports the iso standard, an er subform of spr is generated, which you find in the search of er.
Yours and this I don't put my hand on fire, I should try, it seems like a kiss on the list to be solved.
OK on the list, but after 2 years I can see where it is on the list?
No, no, no, no, no, no, no, no, no, no, no, no.
So you can't even help me with it, can you? :
Yes.. users solidworks of the forum and possess an active subscription, can report the problem to their var, if they also verify the anomaly.
and how do I report the vs? Where am I wrong?
I don't know what to say to you... others can do it, and you don't... ask a couple of questions and read well.
p.s:do not confuse bugs with er, although they are called xywz spr.
in this topic we treat er.
