Devis
everyone, someone can explain to me the process of building a hood that has as its base a measure of 600x500 with a height of 450, and the arrival above always painting of 200x150. mamiera thickness 15/10. Thank you for your help.
fixed the annex the sketches were thwartedsee if this example can help you,
Keep in mind that I can't use the program
hi, you solved the problem of devis in the sense that the hood opens properly. Keep in mind that in solidworks you usually keep the insertion bar at the bottom of the tree, otherwise when you open a set, you will see signs.see if this example can help you,
Home file you have to click save by name. see the list of file type and look well that there is dxf and dwg.. It seems to me down.in response the message: "I add that to make already cleaned dxfs for laser cutting you can save by name directly the 3d sheet model in dxf. you just have to select whether to include bending lines or not"
from the 3d model I clicked on "Save copy" but in type selection I did not find dxf format. should I select a different description? Thank you.
