simbol
Good evening!
I am modeling with catia v5r18 a bolted joint between two hea profiles, which happens through two fasteners on the souls of the profiles.
I would like to ask what kind of bond you have to impose on the bolts, I tried with the "property of the bolted connection" with reference to a constraint (created in the assembly design) between the bolt axis and the hole axis, and I tried to define this property with every plate that "cuts" the bolt (the outer load is applied to an extreme of one of the two hea), but it gives me problems, because it says that my connection is designated.
How can I do that?
Thank you so much!
simbol
How can I do that?
Thank you so much!
simbol
