but where is it? (some management problems)
  • Thread starter Thread starter Brethil
Nono, no analysis or what. .
I have to insert them into the final axieme and then in the future render everything, only that bolts must necessarily be visible in the axieme now put 2 images
Basically I need to place the bolts or set of 1 bolt plus washers and dice (as in photo) in the .iam final file...only that with my pigeon it struggles and serialize for each hole...and maybe you are proposing a solution but I'm struggling to understand that I have to...
Don't hate me:
No hate.
If you have to see them all, there's little to do
can not have taken it "new" 7-8 months ago and mount a xeon to 3 ghz and xp! host!
I wouldn't bet. There are people selling that she's just convinced she knows what she's selling. and this includes cmq good faith... :biggrin:
No hate.
I mean, I have to find a way to serialize them. .
...I'll take my pigeon to axe, at least then they replace it with a fig force! !
tnx cmq tarkus:smile:
I say 2 skemates, looking at the photos, in one where lives are selected, washer, nut.. I see a lot of white pals, are they the imates?
changes anything if you remove them? (I'm saying... )
then I would try to see what happens if I make a set of screws of the dice washer spaced already right (I hope you do not have 1000 different thicknesses) and I would insert those in the axieme, and then proceed to serialization.
I wonder if it's possible to serialize in a rectangular flange or not. I mean a rectangular series only with contour elements.
invisible underarms in the bom.
sincerely the imate symbols you see in the photo, were active because there were selected bolts, once unchecked disappear. I don't know if it's possible to remove them though.
the solution you propose to me for the packaging is great, I will try to enter a already spaced set of nuts bolts and washers in the final axieme hoping that it weighs less serialize that rather than the individual pieces every time... I hope to give you good news:biggrin:
I suppose that a rectangular set of contour elements is possible to do it in the sketch mode, but it is the thought of a self-taught, not to prey for cast gold :biggrin:
when you create a subaxieme from the axieme there is a voice that is called "distinct breakage composed by default". if you impose the subaxieme as hidden, he will not be counted in the separate, but his parts yes, as they were at the level of the main axieme.
Look, I'm sure that's what I said.
I think the problem is, it's a lot.
So every little thing that can make the single less heavy, even if ridiculous "may" translate into a modest resource saving if multiplied for many.
It is possible that you love it in if you do not weigh anything and that even removal becomes useless.
then you have to see also as constraints, because if you use them you need them:d
curious, did you try to draw the screws the dice and the washers?
It will be because I hate the content center... (They are screws of the contained center, yes? )
I'm really a bang. Let's cross my fingers.
look, I am single user and for convenience I copied local dice screws and washers from the inventor's library, others instead I imported them from 3d cads that I found in company, basically I limited myself to assembling them, I didn't draw half :biggrin:
I tried with a subaxieme, but in the "different structure of default components" I don't find how to set it hidden....magari are orbo, but I don't see it..
You have to wax the subaxieme in the main axieme. command creates. opens a window where you can select its visibility or not in the main axieme.
I read only now your 3d, I also have more or less your own problems using inv.2008
it will be because we both have assimilated with thousand million pieces!!! :d (I make cereal silos)
I partly solved by doing more under assemblies, i.e. I do a set by inserting the various columns and save, I take this iam file insert it in a new set and I add the sheets above, possibly serializzo and copio the various iams that I go to insert, but I always try not to load too many iams on a set.
another problem that I have noticed prorpio now and that it becomes very slow when I serialize the screws using the panel series to which they are attached, much better if you make them independent using even as directions the cards axes (it is the same speech when you serialize the various parts)
last trick and create various levels of details, for example I the screws of the plates I have inserted them in an iam file where I have a sheet and all the screws I need to fix it (about 30 ) with its dice, then I created a level of detail by suppressing all the screws (you can use the already default "all center suspended content" if you use the center). ! !
Sorry but I read you only now;
I find very smart your idea to create already a set of bolts bolts bolted and correctly spaced between them with already serialized step and number of columns that I need... a unique .iam entity in place a thousand pallose screws to the right and missing, I thank you:
cmq, you tell me that it is preferable to reduce the detail of my .iam of screws during the creation of the subaxieme; finish it and put it as it is in the final axieme and only at the end to raise the level of detail? I hope I understand. .
I hope as soon as I put your advice to fruit, I will keep you informed about bullying progress.
:finger: thank you very much
